Arduino 2 Stroke CDI Timing
iimagine
Joined Dec 20, 2010
512
Based on a simple schematic for a single coil, no trigger CDI system I found on the net:
Simple CDI.PNGHere, the triggering is done at the crossing from positive to negative, discharging the cap. Simple enough.
To advance/retard the triggering timing, i was thinking of detecting the point at which the positive cycle
starts to fall and feed this into a uC so that it could control whether to fire the SCR right at that moment or
delays it:
Simple MCU CDI.PNGWould this work? I should use an opto-coupler right after the PNP.
Any problems i'm not seeing?
iimagine
Joined Dec 20, 2010
512
To get the maximum possible spark voltage, the SCR has to be triggered at the peak of the negative cycle. This means that I would have to adjust the position of the stator. Since the negative cycle isnt being used but just to trigger the SCR, I figure, why not harvest and regulate it to charge a battery.
