approach allows to send the full 12-bit ADC via Uart
Kittu20
Joined Oct 12, 2022
511
Hello forum members,
Suppose I'm working on an embedded system project where I need to measure and display a voltage range of 0 to 12 V DC on a serial terminal. I'm using a 12-bit ADC for voltage measurement, and my UART is configured for 8N1 at a 9600 baud rate, meaning it can only send one byte of ADC data at a time.
This formula will give the voltage in the 0-12 V DC range based on the received byte.
Code:
voltage = (received_byte * 12.0) / 255.0
I'm facing difficulties in figuring out how to send full 12-bit ADC value via UART.
Any suggestions on how to accomplish this without using sprintf and string.h library?"
35,145
There are a number of solutions to your problem.
1) You can convert 12-bit binary to BCD text. Hence 0000-4095 can be sent as four text characters.
2) You can convert 12-bit binary to hexadecimal characters. Hence 0000-4095 becomes 000-FFF, three hexadecimal characters.
3) You can send two bytes of 8-bit binary values. This allows you to send a 16-bit binary value. You choose the order of your bytes, Big-endian vs Little-endian.
If you want to ensure that the bytes are received in the correct order, you can send 6 bits at a time. This leaves two unused bits which can be used to tag the order of the bits. For example, 01 = low order, 10 = high order, 00 and 11 = error in data.
Papabravo
Joined Feb 24, 2006
22,111
You can also send three bytes with 4 significant bits in each byte. That will allow all of the characters you send to come from the set of printable characters. This can be an advantage in debugging.
Ian Rogers
Joined Dec 12, 2012
1,136
Any reason why not? I use text whenever I can.. The basics behind sprintf() is atoi() or atol() smaller footprint but will do the same.
Ian0
Joined Aug 7, 2020
13,267
9600 baud will send one character every 1.04ms. If the signal does not change significantly in 20ms, then send the top 8 bits, and then add the lowest four to the next sample. (Feed forward error correction).
Then filter the received data with a cutoff frequency of <50Hz.
Kittu20
Joined Oct 12, 2022
511
Thanks! The approach used here splits the 12-bit ADC value into two parts for UART transmission:
  1. The most significant 8 bits (MSB) are sent in the first byte.
  2. The least significant 4 bits (LSB) are sent in the second byte, with a shift.
On the receiving end, these two bytes are combined to reconstruct the original 12-bit ADC value. This method allows the complete ADC value to be transmitted in two 8-bit UART transmissions while maintaining bit order.
35,145
How does that maintain bit order?
If one byte is 1 and the next byte is 15, how do you know which is low and which is high?
Ian0
Joined Aug 7, 2020
13,267
I assume 9600 just for example. I would always choose highest speed
9600 might be the highest speed, if you wanted to send it over a long distance!
For 115200 baud you could deal with a signal that doesn't change much in 175us.
At a guess, FFEC will probably have the lowest software overhead, and you don't have to decide what to do if you receive a high byte without its associated low byte, or vice versa.
