Repairable desBest Approach for Repairability on PCBs (Especially Passive Components)igns
mzarbi
Joined Jan 22, 2025
Helloo Friends,
I’m currently working on a PCB design, and one of my primary goals is to ensure maximum repairability, especially for passive components like resistors, capacitors, and diodes. I want to avoid desoldering components whenever a failure occurs or when swapping components during troubleshooting.
I’ve considered a few approaches so far:
1. Using female pin headers where passive components can be plugged in directly.
2. Utilizing spring-loaded terminals for a tool-free and secure connection.
3. Employing screw terminals for larger components that require firm connections.
4. Exploring ZIF sockets or pluggable terminal blocks for compact yet removable options.
While these concepts seem promising, I’m concerned about:
- Long-term durability of these solutions (e.g., loose connections, oxidation).
- Space constraints on the PCB when using such removable systems.
- The best balance between ease of use and reliability.
I’d love to hear your thoughts on this:
- What solutions have worked for you in creating repairable PCBs?
- Are there specific parts, brands, or designs you recommend for this purpose?
- Have you faced any challenges with removable connections for passive components?
Any advice, product recommendations, or design insights would be greatly appreciated!
Thanks in advance for your help!
Ya’akov
Joined Jan 27, 2019
10,353
Welcome to AAC.
You have two competing requirements, one stated the other one implied by ordinary logic.
Your efforts to make your PCB “repairable” is, unfortunately, going to cost you in reliability. Proper soldering and protection of components (e.g.: conformal coatings) reduce repairability while socketing and other connection strategies that make it easier to repair reduce reliability. It also drives up cost.
A more complete analysis of failure modes and well established techniques to ensure long term reliability night change your approach. Generally speaking socketing active components has some value when they are known to be vulnerable to damage or couple potentially be subject to upgrade.
On the other hand, purchasing high quality passives and properly soldering them in place, carefully considering thermal problems that can occur when high dissipation components are not properly placed and cooled, and (possibly) applying a conformal coating if the environmental exposure warrants it will go much further in preventing failures and subsequent necessity for repair than making passives easily extracted from the board will make the add value to the end user.
The increase in size, cost, and stacked tolerance type failures from the multiplicity of connectors you are proposing just doesn’t suggest a well thought out plan. This is not intended as a cut, or criticism of your intentions—it is meant as a response born of experience and (perhaps) a broader view.
The impulse to make repair easier is a good one, to be sure. Perhaps you will find focusing your efforts on directly beneficial aspects of your project will get you more for your efforts. For example, good informative documentation—including block diagrams, schematics, and troubleshooting guides; many test points with documented voltages and waveforms; use of commonly available components with generous pads to allow form factors other than the particular one you have used so replacement doesn’t depend on that particular component; and careful consideration of thermal issues—the major cause of failure for most value engineered devices.
Good luck, best of success with your design.
mzarbi
Joined Jan 22, 2025
Thank you Yaakov, I just started designing so my focus on repairability is maybe driven by the fact "I will be making many mistakes". But I see your point and thanks again for your insights.
Ya’akov
Joined Jan 27, 2019
10,353
Happy to help.
The thing about engineering solutions is that they are always tradeoffs. Every strength has a complimentary weakness and vice versa. Everything in a practical project will have a budget: time, money, power, space, &c. Every choice will have to be paid for from one or more of the budgets—so working them out from the start is a big help.
In every project you will make mistakes—the number and nature of them will change, but they will always be with you. When you are building prototypes—and you should always build prototypes—don’t try to make them “nice”, just solid enough that whatever problems you are having aren’t because of the construction. Expect to learn from them, and dispose of them.
This is one place where socketing of expensive parts makes sense. You can transfer them to the next prototype much more easily and safely that way. But in today’s world, rework is the norm. Get yourself the tools and learn—and practice—the techniques.
Good luck.
28,488
A big portion of the reliability requirements depends on the application environment for the PCB. Vibration is the main enemy, followed by temperature cycling and heat in general.
My own bitter experience is that close fitting plated thru holes for component leads are the worst possible enemy of repair efforts. The next enemy is very small solder pads coupled with very narrow conductor traces. So there you have the two worst enemies of circuit board repair. Close fitting plated thru holes for integrated circuits are the very worst offenders, in my experience.
Heavy components attached and supported only by their soldered connections are a source of failure, as are connectors for off-board connections that are not otherwise attached to the PCB. They are not repairability problems, only failure sources.
