Old Freezer Repairable?
402DF855
Joined Feb 9, 2013
271
I have an older chest style freezer in the garage and it worked last time I tried, about a year ago. I plugged it in yesterday, and nothing happened except an indicator lit on the front. I tipped it about 45 degrees to get a better look at the electronics, and the compress started up, although it doesn't sound quite right. If I tip it back the noise stops.
Any ideas of troubleshooting? I guessed the compressor was seized. I'm letting it run for a few hours to see if it gets cold.
Thanks!
drc_567
Joined Dec 29, 2008
1,156
... So has it cooled down yet? An initial guess would be that the lubricant, which is normally mixed with the Freon, needs to be redistributed within the system, particularly in the compressor. If it appears that the cooling effect is insufficient, then it may be that some of the freon/lubricant mix has leaked out.
402DF855
Joined Feb 9, 2013
271
Checked it after a few hours, and now the compressor isn't running even when tipped. It just makes a humming noise. I've recharged car A/Cs, can this be done with freezers? But, it looks like the freezer is toast. ;)
drc_567
Joined Dec 29, 2008
1,156
... Adding Freon to the freezer looks like a questionable proposition. If the freezer is not cooling, then it may have a leak in the system, which would have to be located and repaired.
Beetle_X
Joined Nov 2, 2012
84
Does it have a capacitor in the wiring? Have you looked at the factory wiring diagram? Are the condenser coils covered with dust?
