Best approach to sweep 410-525 MHz? PLL/VCO vs ramped timer vs sweep-IC?
farantastic
Joined Nov 26, 2025
I need to implement a frequency sweep covering 410-525 MHz. I’m considering several approaches but want advice on real-world practicality:
  • Simple ramp voltage → timer IC → ??? (drive a timer or oscillator with a ramp) but is this realistic at VHF/UHF???
  • Frequency synthesizer (programmable divider → PFD → charge pump → VCO) but what are realistic expectations on sweep linearity and settling time???
  • Sweep generator IC but are there readily available ICs that produce a linear sweep in this band???
  • Other approaches like direct VCO with varactor + linearized ramp, DDS + up conversion, fractional-N PLL or hybrid methods.
I need a continuous linear frequency sweep (chirp), not stepped. Stepped is acceptable only if the steps are extremely small (effectively continuous). Target is 10 ms for a full sweep, but I can relax to 50-100 ms if required for linearity. Not ultra-strict like radar FMCW; something like ±1-2% frequency vs voltage linearity across the sweep is acceptable as long as it’s repeatable.
