What would the best approach be to attach new wires to this old hardware?
Ed. M.
Joined Nov 8, 2017
41
Please see below. I need to attach an additional set of six wires to the unit (ignore three connectors on the bottom left) and I'm wondering what would be the best approach:
If you remove the solder pads, underneath is a circular hole. Ideally I'd prefer not to remove the existing wires if possible. I was thinking of melting away the solder, then stick the new wire through the hole and wrap it around itself, but I'm thinking there would be better approaches. Maybe there's a connector of some kind I could use? FYI the existing wires are so old they have "fabric" casing (not plastic).
Thanks.
- Ed.
jpanhalt
Joined Jan 18, 2008
11,087
Solder wick + new solder and wires. The question is whether PVC is OK. If not, I would go with MIL-standard aircraft wire with fiberglass or Teflon insulation. Knyar insulation is also more heat resistant.
Ya’akov
Joined Jan 27, 2019
10,355
Thanks.
- Ed.
Without more information, I would label the wires, desolder them, clean up the terminals and re-tin them with decent lead-based solder, then add the new wires, in addition to the old, exactly as the old ones are currently soldered.
Ed. M.
Joined Nov 8, 2017
41
I like your idea as replacing the wires in the picture would be a significant headache. All I've ever used is lead free solder. Would you please post a link to the type of solder you're referring to on perhaps Altex, Home Depot, or Amazon? Are there special procedures for dealing with lead-based solder?
Ya’akov
Joined Jan 27, 2019
10,355
Any solder with a 63/37 alloy will do. This is an example: https://www.amazon.com/Solder-Rosin-Electrical-Soldering-TAMINGTON/dp/B072WN1DMG which would be fine.
I prefer Kester, but you'd have to buy a larger spool, and it would set you back about 25 bucks or so. It would be a good investment if you are doing projects regularly, but it takes a long time to use it all.
35,279
Why do you want to rewire the connections?
Edit: I just reread your post,
I would stick the new wires right in the holes of the solder lugs.
MaxHeadRoom
Joined Jul 18, 2013
30,876
If the wires require any thermal rating, then replace the conductors with the suitable appliance type conductor with heat resistant type insulation.
Max.
Rich2
Joined Mar 3, 2014
254
For a quick easy job, I'd just re-tin the existing old connections so there will be flux on them. Skin and tin 3mm of the new wires and then just tag them on, you won't need to use the solder for tagging them on.
Or you can tin the pcb and solder them straight on there.
drc_567
Joined Dec 29, 2008
1,156
A particular soldering aid is liquid rosin flux, usually sold in small bottles at various retailers. It seems to improve the heat transfer and dispersal, or something of that nature. Use it for both de-soldering and re-soldering.
Here is a brief note regarding flux usage:
Flux Info
Ya’akov
Joined Jan 27, 2019
10,355
Flux Info
Flux cleans off oxides and prevents the formation of a new oxide layer during soldering by excluding oxygen.
In this case, it probably won't be needed since the terminals are already tinned.
MaxHeadRoom
Joined Jul 18, 2013
30,876
Thanks.
- Ed.
If they the old fabric sheathing they most likely are becoming perished etc,
Worth looking at new conductors with suitable modern insulation.
Max.
Reloadron
Joined Jan 15, 2015
7,976
What you have is just an old style Phenolic solder terminal strip. Brings back memories. I would just use a soldering pencil and remove the solder using a solder sucker or braided wick. The old wires look to be, as mentioned, fabric insulated. I would replace with new wire suitable for whatever the project is and use either 60/40 or 63/37 solder.
This is what you have:
Just about any soldering pencil should work fine. Just make sure after desoldering the terminals you thoroughly clean them. Small stiff brush (acid brush) trimmed short and some isopropanol alcohol normally works well.
Ron
Ylli
Joined Nov 13, 2015
1,092
Where has the TS ever said anything about replacing the existing wires? In fact, he has stated that he would rather not have to remove them.
Ed. M.
Joined Nov 8, 2017
41
Ron
Yes that's what I have. When re-attaching the wires, what's the proper procedure? Do I try to wrap each pair or wires through each hole, then solder so that the entire hole is filled, or do I just place the wires across the hole and apply solder to cover them, which is what it looks like was done originally? Can I do this with thin solder or would I need to get some thicker? My iron tip is fairly big. Thanks.
35,279
Either way it doesn't really matter. If you wanted a connection for extreme stress conditions you would wrap the wire around the lug after inserting in the open hole. If you can get the wire through the hole and then solder that would be good enough.
Thick or thin solder doesn't matter. Use solder with a rosin core for electrical work. Just make sure you heat the entire joint and allow it to cool solid before any movement is allowed.
