I have an APC BX1500 which stopped working. For the last year I had to reduce the "sensitivity" of the line input. When the unit failed last month, I ordered new batteries (RBC33) but that did not fix the problem. I pulled the circuit board with the intent of testing/replacing the mosfets in Q1 through Q6 per someone else post with a similar problem. While I was inspecting the board, I found the inductor "Falco 0316 420-0098-0" showed visible signs of burn/melt (see attached). I found the schematics for the BX1500, and this part in location L1 of the "RTH-Bridge DC/AC Inverter" and rated at 650uH/4.5A. I cannot find this part anywhere - Mouser, Digikey or any Google hit. This is a 5 pin device which makes me wonder if it really is an inductor.
Is this an Inductor and does anyone know where I can find a replacement?
