AO3400 N-MOSFET switch not turning off load
FranciscoB
Joined Feb 8, 2014
139
I bought 100 units of the AO3401 and 50 units of the AO3400 from the same seller at the same time (minimum amount, sent in 10 unit strips).
I used the same soldering iron and was careful as when I was using the AO3401 for the other projects without problems. This was the first time using the AO3400.
My soldering iron is a 30W fine tip one, which connects to 220V directly, no transformer. I have been using it for over 15 years and, for example, I have repaired tablet screen ribbon cable tracks with hair-size transformer wire - the temperature is adequate for small stuff.
Only a few moments ago I learned this type of soldering iron may subjects the components to some stray voltages. I tested by holding an smd LED and touching the positive side with the soldering iron, causing it to very lightly turn on.
I guess I have been lucky so far that I havent destroyed more stuff..
dl324
Joined Mar 30, 2015
18,465
Is this seller reputable and knowledgeable?
I bought my AO3400 and AO3401 on Ali Express; because I didn't feel like paying 30-40x more for something from a reputable seller. I don't know if I got rejects or counterfeits, but they work as switches and I haven't encountered anything didn't work. But I haven't checked to see if they'll handle 5A.
dl324
Joined Mar 30, 2015
18,465
I bought the mosfets from this shop: https://www.aliexpress.com/store/1911309
I have ordered from them in the past with problems...or maybe I havent put the parts to test properly.
I consider any semiconductors purchased from Ali Express to be suspect. The sellers know little about anything they sell. I once considered buying a full reel of AO3400 because they're end-of-life. Then I remembered seeing reels of surface mount components being sold in an area of China where all they sell are counterfeits and it wasn't worth gambling $35 that they'd be something close. If I was a counterfeiter, I'd put dozens of good ones at the beginning of the reel.
You can't even be certain that the engineers employed by Chinese companies can even copy open-source designs like Arduino Uno. I have at least one where they substituted LM358 for LMV358. The former is definitely cheaper, but the latter has rail-to-rail outputs that the Uno counts on.
dl324
Joined Mar 30, 2015
18,465
Still above the recommendation. When I get to a computer, I’ll calculate the desired resistance for the desired operation.
There is no recommended resistance. There is essentially zero current going into the gate. I usually use 10k for gate pull-up or down, but 1M will probably work.
dl324
Joined Mar 30, 2015
18,465
A 1M pull-down resistor worked. I didn't measure turn off time for any of the resistors, but that wasn't what the OP was concerned about. A 100k pull-down would work in his test.
