AO3400 N-MOSFET switch not turning off load
FranciscoB
Joined Feb 8, 2014
139
I was attempting to simply blink a red LED by switching a digital pin on my microcontroller High and LOW for 1second, connected to the gate of this Mosfet. The LED remained dim when I expect it to turn OFF completely
I removed the mosfet and tested like in the attached pic. I have tried with two new AO3400.
I must be doing something fundamentally wrong. I expected the LED to be OFF when the switch is open, only turning ON when the Gate is connected to 5V.
peterdeco
Joined Oct 8, 2019
484
You said you expected the LED would shut off when the "switch is open." Does your microcontroller actually bring it low or just remove the B+? If this is the case you need a resistor (try 10K) from gate to source.
FranciscoB
Joined Feb 8, 2014
139
The Mosfets came from a reputable source and the circuit has a resistor from gate to source (as shown in the figure attached to my first post)
FranciscoB
Joined Feb 8, 2014
139
Here is a photo showing the test setup. I have tried with other AO3400 connected the same way. The gate is connected to gnd through 100K resistor; the grey wire is connected to 5V, I expected to have to touch the gate to light up the LED.
I have P-Channels AO3401 bought from the same source and they work properly.
djsfantasi
Joined Apr 11, 2010
9,237
There's nothing wrong with the circuit. He just didn't draw it conventionally which made it more difficult to read.
<image omitted…>
Thanks, his drawings confounded me.
However, I think the pull down resistor is too large a value. I use a 100 ohm resistor, up to 1k ohms. A 100k ohm resistor may not provide enough current to pull down the input and turn off the MOSFET. Admittedly, I didn’t do the calculations.
dl324
Joined Mar 30, 2015
18,460
If you bought from someplace like Ali Express, be aware that the counterfeiters sometimes throw in some good parts so you need to do 100% testing. If you buy from a reputable source, you don't need to do any incoming QA (in general).
dl324
Joined Mar 30, 2015
18,460
I breadboarded the circuit using 100k and then 10k for the pull-down resistor. There was no measurable difference.
dl324
Joined Mar 30, 2015
18,460
Previously I was playing with some 555 IC motor controller and successfuly used the AO3401 as shown in the attached photo:
It would be helpful for you, and everyone else, if you labeled pin function on the IC's. Not everyone has memorized pin function for the 555 timer.
At least your symbol is "better" than National Semiconductor's. They drew theirs backwards:
FranciscoB
Joined Feb 8, 2014
139
The problem was with the Mosfets, I tried with others from a different strip and they are working as expected.
Thank you all for your help.
dl324
Joined Mar 30, 2015
18,460
So you should be asking yourself why they didn't work. Did you damage them? Were they defective? Are they counterfeit?
It doesn't take much voltage to damage them.
