- Joined Jul 18, 2013
- 30,768
I take advantage of Global Shipping to Canada, P\P CA$8.50. Never been charged duty yet!
.I take advantage of Global Shipping to Canada, P\P CA$8.50. Never been charged duty yet!
Yes, shipping charges from China are subject to tariffs in the US, particularly after the end of the de minimis exemption on low-value packages. Effective May 2, 2025, all shipments from China and Hong Kong, regardless of size or value, are subject to tariffs. This includes goods valued below $800, which were previously exempt.
These new costs will definitely change the way I “play” with electronics.As I understand it, the shipping is also subject the tariff.
Google answer:
Maybe that's a good thing in the long run as I also was getting lax at making sure it was close to perfect before ordering a "fast fashion" board from China.These new costs will definitely change the way I “play” with electronics.
Previously, if I found a circuit that I found interesting, but only came as SMT device, I would design my own evaluation board, with plenty of prototyping area. At around $4 including the shipping, this was a good option.
After I had played and probed and thoroughly understood the concept, I could use the remaining boards for an actual project. The prototyping area would be used for ancillary circuits.
Even with real projects, if I wasn’t satisfied with the actual performance or functionality, or I had made a mistake, I could always make a rev2 and upgrade the project.
No big deal, one would only throw away a few dollars.
Those days are gone.
I learned how to make PCBs via Osh Park, on small boards. But they get expensive real quick at $5/in2.OSH PARK is a good domestic alternative for SMALL boards – $5 per square inch for 3 boards.
Did you reflow the solder joints?
Those are all hand soldered with a UtraFine tip and fine 0.015 solder. I sometimes do a heat gun remelt to realigned the parts and to relieve stress from the hand soldering. I use magnification with many lead controller chips. I look at the screen on my left side and move my hands while viewing the screen to do each solder joint without looking directly at the PCB. It's a learned skill, like touch typing without looking at the keys.Did you reflow the solder joints?
Tariffs are applied when the product lands in the country. If you pre-paid, JLC should refund the excess.Crap, I ordered from JLC like hours before I read the news that tariffs are reduced to 10% on May 14. Ug.
