Anyone has ordered from JLCPCB post-sanctions?
Jon Chandler
Joined Jun 12, 2008
1,649
So the first board shown above is current,cand the 3rd is from February? Shipped via the same method?
It was my recollection that shipping had gone up, but double? Wow. And OUCH. Still beats anything you can do domestically by a long shot.
Since JLC is paying the tariff (charging YOU of course), do you think that avoids the threatened "minimum tariff" of a hundred or two hundred bucks? Let's hope so!
BobTPH
Joined Jun 5, 2013
11,662
As I understand it, the shipping is also subject the tariff.
Google answer:
Yes, shipping charges from China are subject to tariffs in the US, particularly after the end of the de minimis exemption on low-value packages. Effective May 2, 2025, all shipments from China and Hong Kong, regardless of size or value, are subject to tariffs. This includes goods valued below $800, which were previously exempt.
schmitt trigger
Joined Jul 12, 2010
2,260
Google answer:
These new costs will definitely change the way I “play” with electronics.
Previously, if I found a circuit that I found interesting, but only came as SMT device, I would design my own evaluation board, with plenty of prototyping area. At around $4 including the shipping, this was a good option.
After I had played and probed and thoroughly understood the concept, I could use the remaining boards for an actual project. The prototyping area would be used for ancillary circuits.
Even with real projects, if I wasn’t satisfied with the actual performance or functionality, or I had made a mistake, I could always make a rev2 and upgrade the project.
No big deal, one would only throw away a few dollars.
Those days are gone.
Maybe that's a good thing in the long run as I also was getting lax at making sure it was close to perfect before ordering a "fast fashion" board from China.
Did you reflow the solder joints?
Those are all hand soldered with a UtraFine tip and fine 0.015 solder. I sometimes do a heat gun remelt to realigned the parts and to relieve stress from the hand soldering. I use magnification with many lead controller chips. I look at the screen on my left side and move my hands while viewing the screen to do each solder joint without looking directly at the PCB. It's a learned skill, like touch typing without looking at the keys.
