If you were going to use the antenna, what parameters would be important to you?What are the Parameters required to validate while testing Antenna.
Average gain and antenna pattern is what I usually tested. However, you failed to inform us what kind of antenna, its use and its size that you want to test. All these factors will influence what kind of testing is required.What are the Parameters required to validate while testing Antenna.
| H | Need help to design an array antenna | Wireless & RF Design | 1 | |
Patch antenna phased array | Wireless & RF Design | 8 | |
| B | Antenna SWR | General Electronics Chat | 2 | |
Broken U.FL / IPEX antenna cable connector on Meta Quest 2 controller – repair options? | Technical Repair | 0 | |
TV Antenna Amplifier | Technical Repair | 5 |
