Anolouge voltage ramp inverter needed
atvtony
Joined Mar 9, 2019
6
So here s the deal I need a circuit that will change input 0 to 5v ramp going this way / to a output 5V to 0 ramp going this way \ in other words 0 = 5 and5 = 0 and everything in between what do you suggest ?
for a circuit ?
ericgibbs
Joined Jan 29, 2010
21,517
hi atv,
Welcome to AAC.
That conversion can be done by using an OPA circuit.
Do you have access to general purpose OPA's.
E
atvtony
Joined Mar 9, 2019
6
I have a MCP6002 that I built a circuit with but it dont seem to work not sure If i did something wrong or if the circuit just wont do what i wasnt it to do
atvtony
Joined Mar 9, 2019
6
so Im changing 100K to 10K is thats the only difference ? are the resistor values that critical ? or do I have a bad IC ?
38,624
The values are not critical, but a higher value increases the offset due to the input offset current, which is very low for the MCP6002.
How exactly does your circuit not work?
What are all the node voltages?
atvtony
Joined Mar 9, 2019
6
im going to change the IC maybe it was bad ... I got no output dc volts no matter what I put in or the most it would give me is .223 v
which I consider no oiutput
