See post #19.The easiest is probably to write equations for all the current into the summing node (whose sum has to be zero).
For example, the current from the output to the sum node will be the output voltage divided by R7 plus the output voltage minus the Zener voltage divided by R8.
I leave the calculation for the input current to the sum node and solving the simultaneous equation, to you.
Make sense?
