analyzing current limiting switch circuit
yef smith
Joined Aug 2, 2020
1,485
Hello , from the The Art of Electronics (3rd edition) book there is the following circuit which is basickally a current limiting high power switch.
Is there a way I could loggically approximate the amount of current this switch will allow?
Thanks.
wayneh
Joined Sep 9, 2010
18,181
Ever use LTspice, the free circuit simulator? The learning curve is a little steep but once you learn it you'll have a great tool for answering this and many other questions. It's used by many here that can help you get it going.
@bertus beat me to it and gives the answer I almost did.
38,920
When the current through R5 generates a voltage of about 0.6-0.7V, Q3 starts to turn on, raising Q2's gate voltage.
This reduces Q2's gate-source voltage and when it approaches the Vgs(th) voltage, it will start turning off, limiting the load current.
Since you seem to have a lot of questions about various circuits you find, I also suggest you learn to use the free LTspice simulator from Analog Devices, so you can answer most of them yourself.
yef smith
Joined Aug 2, 2020
1,485
Hello crutschow,I want to lear how you see things and set the simulation properly.I have built the simulation attached.Q2 is a PMOS transistor it can be both saturated or linear, also the PNP and NPN.
what is intuition for each resistor R1 R3 R2 I'll know that each one of them is conducting properly?
Thanks.
yef smith
Joined Aug 2, 2020
1,485
Hello Eric, I want to see the analog logic ,Why did you add Vr source.also could you say what is the logic behind shoosing R2 R1 R5 values?
Suppose we didnt have the exact values for R2 R1 and R5 what what you do in the simulation to find the exact values.
Thanks.
ericgibbs
Joined Jan 29, 2010
21,627
hi yef,
Please post the design parameters you require.
eg: the steady state Vout voltage & Current, and the Current value at which the current limit occurs.
E
BTW: Why have you inverted Q3???
ericgibbs
Joined Jan 29, 2010
21,627
hi yef,
This sim may help you understand how the circuit functions.
R3 value is stepped 0.1R >> 0.5R in 0.1R increments
also
R1 is ramped down 20k >> 5k
E
yef smith
Joined Aug 2, 2020
1,485
Hello Eric,thank you for the plots. could you give basic specs for such circuit?
R2 and R1 will deside the currents.
The current across R1 will deside the operation of Q1.
How would you choose the values for R1 R2 and R3?
yef smith
Joined Aug 2, 2020
1,485
Hello , We have Q3 which is controlling the p-channel mosfet.
When Q3 is open then Vgate of the mofet is 12V and mosfet source is 12-0.7V(Vbe condition of Q3)
So Vsg of the mosfet will be -0.7V .
Three questions :
1. PMOS cannot open with Vsg -0.7 where is my logic wrong?
2.How can we know the Q3 will be open?
3.Do we need to use p-channel enhasment mode for this case?
