Analysing equations of inductance and capacitance
kiroma
Joined Apr 30, 2014
212
Hello.
Ic=C*dv/dt comes from Q=CV.
V(Voltage across inductor)=L*di/dt comes from what?
I found that integral of (v*dt)=L*integral of (di)
Replacing v by R*I, and replacing I by dq/dt we have that
Integral of (R*dq/dt*dt)=L*integral of (di)
Integral of (R*dq)=L*integral of (di)
OBS.: limits are from 0 and 0 to q and i, respectively.
R*Q=L*I
L=RQ/I
So that means inductance is proportional to the resistance of the inductor?
I think I did a big mistake and a maybe a big confusion but, at least, I tried to find.
The question remains the same.
studiot
Joined Nov 9, 2007
4,998
This doesn't work.
The ideal inductor has zero resistance so your second equation above, is nonsense. Where did you get the idea that v = ir in an inductive circuit?
MrAl
Joined Jun 17, 2014
13,793
Hello.
R*Q=L*I
L=RQ/I
If i understand you right i think you want to go back to Faraday which would lead to:
N*dPhi/dt=L*di/dt
for N the number of turns, Phi the magnetic flux, L the inductance, i the current.
or another interesting way to look at it is:
dPhi/di=L/N
kiroma
Joined Apr 30, 2014
212
This doesn't work.
Haha
That's why I thought I was doing a big mistake
Answering your question, sincerely, I don't know, haha.
Thank you MrAl.
kiroma
Joined Apr 30, 2014
212
N*dPhi/dt=L*di/dt
dPhi/di=L/N
So it means that N*dPhi/dt=Vl=L*di/dt?
Did Faraday found this?
MrAl
Joined Jun 17, 2014
13,793
Faraday found:
E=N*dPhi/dt
or the signed form:
E=-N*dPhi/dt (i think attributed to Lenz)
L is the constant of proportionality that relates the flux to the current:
L=Phi/I
just as capacitance C is the constant of proportionality that relates the charge to the voltage:
C=Q/V
L has a physical origin just as C has a physical origin, both dependent on the geometry.
Another view is through the stored energy:
U=(1/2)*C*V^2
U=(1/2)*L*I^2
Inductance is the dual of capacitance, so often when you see voltage in a capacitor equation you'll see current in an inductor equation...as current is the dual of voltage.
L is the first letter of Lenz, in his honor (almost same equation as Faraday).
C is the first letter of Capacitor, in honor of Mr. Capacitor (just kidding) :)
kiroma
Joined Apr 30, 2014
212
Faraday found:
E=N*dPhi/dt
or the signed form:
So it's correct to say that E=-N*dPhi/dt (as my professor said, when I wrote on the board the equation N*dPhi/dt=L*di/dt, "isn't a minus missing?!" Lol) and not E=N*dPhi/dt (incorrect)
Am I right?
MrAl
Joined Jun 17, 2014
13,793
Yes, and i think it was Lenz who clarified the sign of the result, not Faraday, but dont quote me on this rather look it up on the web and maybe you can make a note here in this thread.
