analog unit step circuit
Bamerni
Joined Jun 26, 2016
53
Hello everyone
Is it possible to generate a real unit step function or it is only available in literature?
Is there an electronic circuit that generates such function?
Thank you in advance
#12
Joined Nov 30, 2010
18,224
Sure. An Lm3914 can make steps and the amplitude of the outputs are modified by resistor values so they add up as the chip moves from one step to another. This is not the only chip which can do this.
OBW0549
Joined Mar 2, 2015
3,565
The unit step function has zero rise time and fall time, since it is the integral of the unit impulse which has zero width. It cannot be realized in a physical circuit.
#12
Joined Nov 30, 2010
18,224
That's an aspect I didn't think of!
I interpreted the question differently.
Bamerni
Joined Jun 26, 2016
53
It is not important to have zero rise time in my application, I just need a circuit that changes from zero to specific voltage after a specific time and remains at the final value as long as the circuit is on
OBW0549
Joined Mar 2, 2015
3,565
Oh. You said "unit step function," which has a very specific meaning in circuit theory. It sounds like what you need is a thing called a "time delay circuit." Google that phrase, and you should find plenty of examples.
