Analog to digital converter IC?
35,322
Do you have schematics and Commodore 64 Programmer's Reference Guide?
Are you aware that the C64 has POTX and POTY inputs to the 6581 Sound Interface Device (SID)?
Green Bean
Joined Mar 31, 2017
126
Yes I have a programmers reference guide, and yes I know, but I want to be able to control several registers without code, and so I can't use those.
GopherT
Joined Nov 23, 2012
8,009
You should give up the pot and ADC as a source of binary values. You can use something that looks a lot like a pot. A 4-bit rotary switch that can out put the high/low values needed. You can even add LEDs and pull-up resistors to see the value that is set. Two 4-bit rotary switches (16 binary values each) make an 8-bit.
33,361
I'm trying to use a potentiometer to send a digital signal to an 8 bit register in an 8 bit computer.
A bit more detail here would be helpful.
Are you trying to use the pot as a way to set a register to a specific value? Or are you just trying to have the value in the register closely related to the current position of the pot?
Green Bean
Joined Mar 31, 2017
126
This sounds like a good idea. I will look into this.
