That latter would be the far more sensible way to go, unless you need the pot in order to "remember" what the previous value was.Multiplexers. Actually though, I may just use 1 pot and several buttons to select the addresses.
Yes I have a programmers reference guide, and yes I know, but I want to be able to control several registers without code, and so I can't use those.Do you have schematics and Commodore 64 Programmer's Reference Guide?
Are you aware that the C64 has POTX and POTY inputs to the 6581 Sound Interface Device (SID)?
You should give up the pot and ADC as a source of binary values. You can use something that looks a lot like a pot. A 4-bit rotary switch that can out put the high/low values needed. You can even add LEDs and pull-up resistors to see the value that is set. Two 4-bit rotary switches (16 binary values each) make an 8-bit.Yes I have a programmers reference guide, and yes I know, but I want to be able to control several registers without code, and so I can't use those.
A bit more detail here would be helpful.I'm trying to use a potentiometer to send a digital signal to an 8 bit register in an 8 bit computer.
This sounds like a good idea. I will look into this.You should give up the pot and ADC as a source of binary values. You can use something that looks a lot like a pot. A 4-bit rotary switch that can out put the high/low values needed. You can even add LEDs and pull-up resistors to see the value that is set. Two 4-bit rotary switches (16 binary values each) make an 8-bit.
| Thread starter | Similar threads | Forum | Replies | Date |
| T | 3-Way Class D DSP Amp with Analog & Digital Inputs | Analog & Mixed-Signal Design | 8 | |
| M | Analogue SPDT Circuit | Analog & Mixed-Signal Design | 30 | |
| U | Digital, Analog, and Power | Analog & Mixed-Signal Design | 12 | |
Digital & Analog | Microcontrollers | 3 | |
| E | How to split analog and digital voltages | Power Electronics | 11 |
