Analog multimeter needle "offset"
jpanhalt
Joined Jan 18, 2008
11,087
Have you tried a watch hand remover, which is similar to a gear remover but on a much smaller scale?
In your initial post, you mentioned that with a fixed voltage, the needle came to rest in various positions. To me, that does not mean you need more "grease." If the movement is jeweled, it's rare to need oil, except maybe after cleaning. A couple of years ago the temperature gauge on my tractor acted like that. To me, it was obvious the needle was slipping and was easily fixed. Saved $50.
My watchmaker tools are more than 50 years old. Don't use them every year, but they have proved well worth what I paid for them.
jpanhalt
Joined Jan 18, 2008
11,087
I did not mean to imply it was identical to a watch movement. Nevertheless, the needle is attached to a shaft, as was the temperature gauge on my tractor, and not "physically" connected directly to and only to the spring coil.
It's on a shaft, and that connection can become loose. Here's a typical D'Arsonval movement:
Maybe you can show how you think the needle is attached?
KeithWalker
Joined Jul 10, 2017
3,614
This is how the needle is usually attached on a moving coil meter. It is fastened directly to the coil, with the hairspring and bearings mounted above it.
Elerion
Joined Sep 11, 2017
125
Is it ok if the needle is not sticky, but the meter is only accurate when placed horizontal (or almost horizontal)? The readings are about 2-3% lower when used in vertical position? Tested on Vdc and ohms. Is this common for analog (passive) multimeters?
KeithWalker
Joined Jul 10, 2017
3,614
If they are properly balanced, they should read the same in any attitude. Here is the way to re-balance it - thanks to W. R. Triplett
Elerion
Joined Sep 11, 2017
125
Thank you!
Just in case I didn't get it right, when the instructions say "horizontal position", is it like when the meter is layed on a table (like in this picture)?
Is "vertical position" like the regular position of a Simpson or AVO?
35,070
I would adjust the zero adjustment on the front face of the meter for your most common orientation of the meter.
Don't lose sweat when the meter is oriented differently.
Otherwise its time to move on to a DMM (digital multimeter).
KeithWalker
Joined Jul 10, 2017
3,614
Thank you!
Yes, that is correct.
If you need to adjust the side weights, it is easier to just bend the needle slightly, close to the coil, towards the light side rather than mess with the weights. If you do that, you will need to re-adjust the zero.
