That sounds like an easy and inexpensive way of controlling the level on the tank. If it is a gravity feed distribution system, knowing the exact level of the tank will help in calculating the daily water demand and for leak detection.I maybe missing something in this, wouldn't be the first time. If this is just for a water level for a drinking water system, why do you need to know all of the levels? Wouldn't a high level to shut the pump off, and a low level to turn the pump on, be enough? And the easiest and least expensive way would to be to use two automotive coolant level sensors. Drill and tap a hole at both levels and insert the sensor and wire them up. Just the first one I came across that looked like it would work - http://www.fozmula.com/product/capacitance-liquid-level-switch-s87/
