Colin55 If you mean 1 pF it could be a lot more sensitive than that! Anyhow very small values of capacitance change is ok for heterodyne sampling or bridge sampling circuit. Just as long as error margins are kept to minimum!Are you fooling yourself?
The capacitance increase will only be one puff per cm.
colin55 I suppose that would work so would washer fill diaphragm (which basically just weighs column of water) but I say capacitance method is less hassle cuz it needs only one small part to be safe for contact with potable waterIf you want accurate measurement, get a washing machine float from the tip.
