An amplifier circuit for a piezoelectric disk for ultrasound generation
Isabella__
Joined Apr 26, 2022
15
Hey guys,
I need your help. I am a bit lost. I have to build an amplifier circuit for a piezoelectric disk for ultrasound generation in university.
The technical data (piezoelectric disk):
Resonant frequency = 80 kHz
Electrical capacity = 35 nF
Max. Supply voltage = 400 V
In the university I have a function generator which supplies me with an alternating voltage with the desired frequency (70 kHz). I think it would make most sense to build a driver circuit.
I would be very grateful if you could explain me how to proceed.
How should the amplifier circuit look like, which components and what else I have to consider.
Thanks in advance
ericgibbs
Joined Jan 29, 2010
21,653
Hi Isabella,
Your Sine amplitude will have to be greater than 0.7V on the positive half cycle in order to drive the transistor into conduction.
What are you setting the Vsupply to the Collector load.?
What is the Power rating of the Disk.?
E
Isabella__
Joined Apr 26, 2022
15
Hi Isabella,
E
My input signal is a sinus wave with 15 V frequency 70 kHz.
Sorry but i can't find the power rating of the disc?
ericgibbs
Joined Jan 29, 2010
21,653
hi Isabella,
So what you are asking is to step a 15V 70kHz Sine wave up to what voltage Sine wave.?
Do you want the output Sine wave to swing positive and negative about zero volts.?
What will be the purpose of driving the disk.?
ie: what will be ultra sound signal be used on.?
E
35,322
The piezoelectric disc does not require a sine wave. It really depends on what you plan to do with the disc.
You need to find the datasheet for the disc so that we know its requirements.
If you need better control of the shape of the waveform emitted by the disc the LM675 power amplifier might be suitable.
Isabella__
Joined Apr 26, 2022
15
hi Isabella,
E
Yes the outputsignal must be also sinus wave swing to +/- 400 V.
The disc generate an ultrasound with a frequency 70 kHz.
After i generate the ultrsaound i will mess the sound with a mems microphone.
The function generator can give me a sinus wave max +/- 15 V thats the problem.
35,322
+/- 15V from the function generator is not the problem.
+/- 400V sine wave is the problem.
We can do this with a 0-400V square wave with a single transistor.
Please tell us what you are attempting to with this.
Isabella__
Joined Apr 26, 2022
15
I use a sinus wave because i want generate an ultrasound with the frequency 70 kHz and when i use a sinus wave i don't must add something to get a frequency of 70 kHz. The Screenshot is the only Datasheet what i find.
35,322
We have heard what you are saying but you still do not understand.
We can generate a 70kHz wave from a function generator, sine or square wave.
The disc does not need a sine wave to operate.
Most piezoelectric transducers have a resonant frequency. If your disc resonates at 70kHz it will emit a sine wave when driven from a square wave signal.
Isabella__
Joined Apr 26, 2022
15
Okay i'm not sure about that because my teacher wants me to use a sinus wave. Thats why i use a sinus wave. But my question is how can i achieve a voltage gain up to 400 V
35,322
Well then go back to your teacher and ask if a sine wave is absolutely necessary or if a square wave would also work.
Isabella__
Joined Apr 26, 2022
15
Okay i ask him hey says the transducer cannot follow a square signal.
So I MUST use a sinus wave :(
I'm sorry but i don't what i should do now.
35,322
To allow us to assist you better:
1) post a photograph of the ultrasonic disc
2) tell us what is the nature of the project
3) tell us the level of course and schooling, is this secondary or university level?
