In normal operation you release the button before pressing it again. What happens if you start with the amplifier off, then hold down the button for more than the 8 seconds? Also, if you start from off, turn it on, and immediately try to turn it off again, does it behave the same way as if there was a gap between the two operations?Thank you @Yaakov, that was what I thought!
Good point @k1ng 1337, I'm really trying to learn the basics, but it is also good for me to learn by doing.
I have tried to undo everything and checked that it is working just like before, so I think it should be fine!
At least I have ordered everything now and hopefully it will work somehow, but I expect to run into problems when I try to connect everything. But I will try, I really want it to work.
I have a question in the mean time (I have been trying to search and read about it, but can't really find anything). I understand @Yaakov description, but what I don't understand is that my amplifier is on for about 8 seconds and then off for maybe 1 second. But I just need to push my button very fast to turn my amplifier off.
Why would the amplifier be set to go back to open mode after 8 seconds? Is it the 555 timer we saw on my images that is controlling this behaviour?
About the circuit that I'm now trying to build: would it send pulses so that my amplifier wont think it needs to go into open mode and stays in closed mode all the time?
So you can see your shorting link was just like the button, and the fact you have to wait shows that there is probably a discharging capacitor involved.If I hold the button after starting the amplifier it starts to behave exactly as when I soldered the wire between the poles, turning itself on and off.
If I immediately try to turn it off it doesn't work, I have to push a few time (or wait like 2-3 sec) before it turns off.
Will this work with the circuit @LowQCab posted?
Here's what's happening:Okay, so the circuit will simulate 1-short button-press to make the amplifier "think" it is on even though the button wasn't pressed?
And since it then "think" it's a closed circuit it won't turn off after a while?
Just trying to understand
It's a very cheezy Freeware-Program called "Ideal-Circuit".Just for interest, @LowQCab, what program are you using for simulation and circuit build?
That’s great to hear. It was certainly an opportunity to learn new things. Do you plan o pursuing more electronics projects?
