The theoretical maximum efficiency of a class B amplifier is 78.5%.What is your designed power limit for the amp?
The transformer should have a bare minimum of 10% more VA rating. Preferably 25% more.
How do I get 3 A secondary rating for the transformer in multisim or any simulator?like I said....3A secondary rating would be enough with plenty of smoothing cap
do i need more capacitors?i used the 1n5402G diodes with 200 V and 3 A. added the 10000uF capacitors. it has 51 V and -51V. Do I need to treat the amplifier as a load for the supply and get its equivalent impedance and use it as a load for the supply? its only powering it to half of what it should. sorry, i still cant figure it out.
You have a 100uF capacitor across the transformer secondary. That would have an impedance of 31Ω and so a current of 1.6A would flow through that capacitor - not good. For the simulation, remove that capacitor. In the real world you might connect a capacitor with a much lower value, perhaps 100nF, to reduce high frequency interference from the mains supply reaching the amplifier.do i need more capacitors?
I was speaking for a practical situation.How do I get 3 A secondary rating for the transformer in multisim or any simulator?
It doesn't go up to 60 Watts when i make the 20k and 500 Ω to 2k and 50 ΩI see two possible problems with the amplifier.
The maximum output voltage swing from Q2 is limited by the voltage drop across the emitter resistors to about 75% of the supply voltage.
Also, the diodes on the bases of the output transistors can turn off those transistors but the only source of current to turn them on is the 20k resistors. Try reducing the resistors in that chain by a factor of ten - 2k and 50Ω.
You also need to address the lack of drive from Q2.It doesn't go up to 60 Watts when i make the 20k and 500 Ω to 2k and 50 Ω
what do you mean by lack of drive? can you please elaborate?You also need to address the lack of drive from Q2.
