Laptop charger as amplifier power supply
PaPiャSly
Joined Dec 25, 2022
47
So im using this 19v 4.74A laptop charger to power my amplifier which is rated for 12-24v 5a but my concern is if there's a difference between a laptop charger and a a proper 24v power supply and i might be damaging my ampli in the long runIMG_20221229_154404.jpg
dl324
Joined Mar 30, 2015
18,523
I'd be more concerned about it being rated at a current lower than what the amplifier specifies.
ronsimpson
Joined Oct 7, 2019
4,894
I use them on all kinds of projects.
Most audio amplifiers use very little power when the volume is down.
4.74 is almost 5A.
If you use the lowest resistance speakers (2 ohm) and pound the base so the neighbors can hear, maybe you will use the full power. Without knowing much more about the amplifier we can't know what the current might be.
Audioguru again
Joined Oct 21, 2019
6,826
"For use with information technology equipment only" printed on it.
Because an amplifier makes a huge squealing noise when powered from it? Because it causes an amplifier to produce swearing?
BobTPH
Joined Jun 5, 2013
11,678
It is almost certainly a bridged class D amp. At 19V, the most current you can get into an 8Ω speaker is 2.3A, 4.6 for stereo. real power usage for music will not be anywhere near that high, so, if you stick to 8Ω speakers, you should be okay.
Audioguru again
Joined Oct 21, 2019
6,826
If an amplifier volume control is turned up too high so that it is clipping or if you play acid rock noises (same problem) then the amplifier current can be double its rating and cause this 19V, 4.74A (90W) rated power supply to catch on fire.
Jon Chandler
Joined Jun 12, 2008
1,659
The switching power supplies I have tested have shown a remarkable self-preservation instinct. When their rated current is exceeded, the voltage falls remarkably. Sorry, no fire, flames, smoke or damage.
Jon Chandler
Joined Jun 12, 2008
1,659
I've used many power supplies stating that without problems. If you claim they will catch fire, please provide some evidence of your wildly inaccurate claim.
ericgibbs
Joined Jan 29, 2010
21,649
Then why do they say, " For use with information technology equipment only"?
Hi agu,
It just makes the buyer think he's getting more for his money. ie: eye Candy.
As Sigmund said: sometimes a PSU is just a PSU.
Surprised you fell for that one.;)
E
Edited.
