Amplifier application
luca290799
Joined Apr 4, 2022
60
hi luca,
This is the conventional way to cancel out +/- Voffset on the Vout.
Assume the +/-Vsupplies are stable.
E
Thanks! I've a couple of questions:
I tried this circuit solution and it decreased the offset. In fact, before Vout was [0.5 ... 5]V and now Vout is [0 ... 4.5]V ... but I've the same problem :(
Now I should add 0.5V only to the 4.5V, not also in the 0 .. I need to measure a Vout = [0 ... 5]V.
1) What could I modify in your circuit? (I hope I have explained the problem well)
2) What is the purpose of the 100nF capacitor (C3 in your schematic) you inserted between the non-inverting input and gnd?
3) If I decided to remove the amplifier and connect the potentiometer network directly to the 2.2k resistor ...
I know that I would not have the high input impedance of the amplifier to "isolate" the potentiometer side with the instrumentation amplifier side. But what other problems would I encounter?
(I simulated and it still works the circuit)
ericgibbs
Joined Jan 29, 2010
21,439
hi luca,
C3 is for noise reduction from the +/-12V supplies entering into the Vref voltage.
To change now Vout is [0 ... 4.5]V ... to 0v +5Vout, slightly increase the Gain, reduce the 180R to say 175R as an initial test.
I would have made the 180R as say a 150R resistor in series with a 100R trim point, in order to set the Gain.
E
luca290799
Joined Apr 4, 2022
60
Hello again,
This is the other solution i was talking about. This preserves the common mode behavior and makes sure the output offset is only whatever the op amp input offset is, so if the input offset is 3mv then the output offset will only be 3mv after adjustment if the output of the previous section was adjusted for. if the entire offset is adjusted then it should be zero. The drift will still match the last op amp except the drift of the previous op amps will be amplified somewhat. The LM358 has pretty good drift characteristics though so should be ok.
The two resistors Rx should be the same, maybe 2.2k to 10k.
The two resistors Rp should be the same, maybe 10k each, and the pot 10k also but depends how much offset you have to adjust for.
Thanks for the circuit and the clear explanation!
But I refer you to the answer I gave to @ericgibbs in post #61.
In the circuit you sent me Vout = [0.5 ... 5]V, but I would need Vout = [0 .. 5]V. Voffset is added to both the left end of Vout (i.e., 0.5V) and the right end of Vout (i.e., 5V).
MrAl
Joined Jun 17, 2014
13,702
You will have to clarify that. Left end of Vout and right end of Vout, doesnt make any sense, there is only one Vout :)
ericgibbs
Joined Jan 29, 2010
21,439
hi luca,
As I said, your Pot is the opposite way around in your circuit compared to mine.
Either Rotate the Pot through 180 degrees OR change the setting to 0.6.
CHANGE the wiper of the Pot so that the Vout is 0v, It is a Zeroing Pot.!
This is an example of the circuit with the pot rotated
E
EG 1671.gif.
E
ericgibbs
Joined Jan 29, 2010
21,439
hi,
With the Pot in your circuit set to 0.6 it gives the correct Vout.
E
Devi impostare il valore del piatto in modo che il Vout inizi da 0v:)
luca290799
Joined Apr 4, 2022
60
hi luca,
This shows the effect of stepping the Pot setting.
E
Unfortunately, I still can't figure it out, but these days I will test it in the lab and take measurements directly on the breadboard with the oscilloscope. I still attach a couple of screenshots on the simulation if you want to check where the error is ... but as I said, I will test it directly in the lab.
In any case, thank you both for your helpfulness and for your clear and quick answers.;)
With the Pot in my circuit set to 0.6 it gives this Vout:
With .step param wp .2 .6 .1 I see this:
ericgibbs
Joined Jan 29, 2010
21,439
hi luca,
The plots you post suggest that there is a problem in your set up.
The plot should not flatten out at 100mSec.??
Please post the full picture of the circuit diagram and the asc file.
E
luca290799
Joined Apr 4, 2022
60
hi luca,
E
I've just fixed the problem, now I see [0 .. 5]V. Last question, what is the porpouse of C3?
ericgibbs
Joined Jan 29, 2010
21,439
hi luca,
Good news!
Explained in post #63.
What was the problem you found.???
E
luca290799
Joined Apr 4, 2022
60
