INA118 Amplifier application
Status
Not open for further replies.
luca290799
Joined Apr 4, 2022
60
I had already talked about this type of application in another thread I had opened, but I decided to create a new one because I have an INA118 available.
I've a load cell that gives [2m .. 24m]V for [0 .. 500]kg of weight, and I want a [0 .. 5]V output using INA118.
Since Vo = [306m ... 4.875]V I decided to apply about 200mV of offset to get 5V (when there is 24mV in the input); in fact, in the attached circuit that is what happens:
The problem is that the added offset gives me an output of 500mV when the input is 0mV :(
If you can give me some advice on how to set the potentiometer in order to get: [2m ... 24m]V input for [0 ... 5]V output would be appreciated.
In the meantime, I would like to ask if I imported the Spice model of the INA118 correctly, because I don't want to do dozens of tests on a model that is perhaps corrupted and/or that I made a mistake to importing ... So I am directly attaching the tutorial I saw:
(let me know if this is the right way to import a spice model)
Load Cell: http://www.diniargeo.it/prd/bilance/celle-di-carico/a-compressione/cpx.aspx
Status
