Am I OK using this SSR?
big10p
Joined May 25, 2013
35
Hi
I posted recently about spark suppression on an EMR, but have been unable to get a snubber to work, so have decided to try using a SSR instead. I am using this SSR to power a CRT PC monitor and an LED strip light. It seems to be working fine, but I have a couple of novice questions concerning long-term use:
- This SSR is of 'zero crossing' type which I understand is used for resistive loads. I guess the LED light is resistive, but the monitor will be capacitive or inductive? Will long-term use damage the SSR or the monitor/LED light? Is it dangerous?
- Do I need a heatsink? From the quick test I did, the SSR didn't even get warm, but will it gradually heat up over time? I don't know what the inrush current to the monitor is (it has a degaus coil that engages every time it's switched on), but the operational current is no more than 1amp.
I would be grateful if you knowledgeable folk could clear up these points of concern I have. Thank you!
LowQCab
Joined Nov 6, 2012
5,101
A "Zero-Crossing" Switch is easy on everything, including its self.
That's why they were created.
A Heat-Sink is always good insurance against an unforeseen situation,
even if You don't really need it.
The SSR will have to be able to withstand Short-Circuit conditions until a Fuse can blow,
be sure to include an appropriate Fuse, they're cheaper than a new SSR.
big10p
Joined May 25, 2013
35
Thank you for the reply. I will fit a heatsink. I am using the SSR inside an arcade videogame machine, which is fused at the mains plug and at the machine connection (5amp fused mains filter, I think). Do I need to fit an additional fuse specifically for the SSR? Thanks again.
MaxHeadRoom
Joined Jul 18, 2013
30,706
They can also be used for inductive loads.
Most off the shelf versions ARE zero-cross switching,
The motor is an inductive load.
LowQCab
Joined Nov 6, 2012
5,101
The need for Fusing is a judgment call, which will be based on what You are switching
and the Wiring practices, length of run, and potential of shorts occurring.
I would say that powering a CTR Display qualifies as hazardous.
The Power-Supply being Fused is a good thing, but not necessarily adequate.
The SSR is rated for ~10-Amps, that's good,
your Load might normally surge to ~5-Amps on start-up,
so I'd install a 5-Amp Fuse at the Power-Input to the SSR
just for additional peace of mind.
big10p
Joined May 25, 2013
35
Good information. Thank you.
