ALternative to regulator MST5333BTG
ep.hobbyiest
Joined Aug 26, 2014
167
Hi
i have one board which has this regulator which i am not getting nearby market. I am looking for alternative to MST5333BTG regulator.
jpanhalt
Joined Jan 18, 2008
10,210
The first step in trying to find a substitute is knowing what you are trying to replace.
So, let's start at the beginning:
What voltage are you trying to regulate?
What output do you need?
What current do you need?
ep.hobbyiest
Joined Aug 26, 2014
167
actually board i am using is got damaged and before this i never checked the input voltage and output voltage of the regulator.
Let me check if i am getting anything information.
colinng
Joined Sep 2, 2020
Hi
If you need a replacement part, this PD Trigger/Decoy board has one:
https://www.aliexpress.com/item/4000001795843.html
But seeing as a whole spool of the regulators is $9.00 I am assuming the $4.45 Trigger/Decoy would seem expensive.
I would guess the regulator outputs 3V3 because the main chip on the Trigger/Decoy is an MCU that takes 3.3V supply.
MCU: F150G8|CE87922|AJ1830
The input to the regulator must tolerate at least 20V, because the USB PD 2.0 and 3.0 standard go up to 20V.
