Alternative to pull down resistor?
kenw232
Joined May 18, 2009
57
I have a gate of an SCR that should be pulled to ground when off. But if I connect it to ground via a pull down resistor I will fry the gate from excesssive backemf from a high voltage pulse coil. I cannot stop the backemf, flywheel diode does nothing. So I appear to be stuck with a floating gate.
Are there any alternatives to pull my gate down or make sure it is otherwise off and does not have any parasitic capacitance which might leave it high? Its currently being turn on and off by an ardunino digital pin out and a 100 or so ohm resistor in series.
#12
An SCR is not a CMOS device. It requires current to turn it on. Just don't apply enough current to turn it on when you are not applying the turn-on voltage.
BillB3857
Joined Feb 28, 2009
2,573
Another option would be to use a gate pulse transformer. The secondary would keep the gate at cathode potential unless pulsed by energy to the primary.
Roderick Young
Joined Feb 22, 2015
408
I'm having trouble visualizing how the high voltage pulse can get to the gate of your SCR, sorry. Can you sketch a schematic of your concern? The pull down resistor from gate to cathode can be a large value, like 100k, and you could put a small value capacitor in parallel with that for additional noise immunity.
