I have set up a Library to drive SSD 1309 with TMS320F Series MCU but I am getting a Missing Row.
SPI Initialize With * bit Mode
C:
void SPI_sendCommand(Uint16 command)
Uint16 volatile dummy = 0;
LCD_CS_LO;
LCD_DC_LO;
while (SpiaRegs.SPISTS.bit.BUFFULL_FLAG != 0){} // Wait until TX buffer is not full
SpiaRegs.SPITXBUF = command<<8; // Master transmits data
while(SpiaRegs.SPISTS.bit.INT_FLAG ==0) {} // Wait until data received
dummy = SpiaRegs.SPIRXBUF; // dummy read to clear INT flag
LCD_CS_HI;
LCD_DC_HI;
void SPI_sendData(Uint16 data)
// Select the LCD controller
LCD_CS_LO;
LCD_DC_HI;
//while (SpiaRegs.SPISTS.bit.BUFFULL_FLAG != 0){} // Wait until TX buffer is not full
SpiaRegs.SPITXBUF = data<<8; // Master transmits data
// LCD_CS_HI;
LCD_DC_LO;
Code:
spi_init()
SpiaRegs.SPIPRI.bit.TRIWIRE =1;//3-wire Mode
SpiaRegs.SPICCR.bit.SPICHAR = 7; // 16-bit char bits
SpiaRegs.SPICCR.bit.CLKPOLARITY = 0;
SpiaRegs.SPICTL.bit.CLK_PHASE = 1;
SpiaRegs.SPICTL.bit.MASTER_SLAVE = 1;
SpiaRegs.SPICTL.bit.TALK = 1; // Enable master mode, normal phase,
// enable talk, and SPI int disabled.
SpiaRegs.SPIBRR = 0x0007; // 15 -> 1Mbps
SpiaRegs.SPICCR.bit.SPISWRESET = 1; // Relinquish SPI from Reset
SpiaRegs.SPIPRI.bit.FREE = 1; // Set so breakpoints don't disturb xmission
cmd_AddressingMode(1);
/* // Initialize SPI FIFO registers
SpiaRegs.SPIFFTX.all=0xE040;
SpiaRegs.SPIFFRX.all=0x2044;
SpiaRegs.SPIFFCT.all=0x0;*/
C:spi_init() { SpiaRegs.SPIPRI.bit.TRIWIRE =1;//3-wire Mode SpiaRegs.SPICCR.bit.SPICHAR = 7; // 16-bit char bits SpiaRegs.SPICCR.bit.CLKPOLARITY = 0; SpiaRegs.SPICTL.bit.CLK_PHASE = 1; SpiaRegs.SPICTL.bit.MASTER_SLAVE = 1; SpiaRegs.SPICTL.bit.TALK = 1; // Enable master mode, normal phase, // enable talk, and SPI int disabled. SpiaRegs.SPIBRR = 0x0007; // 15 -> 1Mbps SpiaRegs.SPICCR.bit.SPISWRESET = 1; // Relinquish SPI from Reset SpiaRegs.SPIPRI.bit.FREE = 1; // Set so breakpoints don't disturb xmission cmd_AddressingMode(1); /* // Initialize SPI FIFO registers SpiaRegs.SPIFFTX.all=0xE040; SpiaRegs.SPIFFRX.all=0x2044; SpiaRegs.SPIFFCT.all=0x0;*/ }
C:void showPic(const Uint8 *pic, Uint8 startPage, Uint8 endPage, Uint8 startCol, Uint8 totalCol) { Uint8 i,j; for(i=startPage;i<=endPage;i++) { cmd_PageStartAddress(i); cmd_ColumnStartAddress(startCol); for(j=0;j<totalCol;j++) { SPI_sendData(pgm_read_byte(pic+i*totalCol+j)); } } } void oledInit() { LCD_RST_HI; msdelay( 1000 ); LCD_RST_LO; msdelay( 10000 ); LCD_RST_HI; SPI_sendCommand( OLED_DISPLAYOFF ); msdelay( 100 ); SPI_sendCommand( OLED_SETDISPLAYCLOCKDIV ); SPI_sendCommand( 0x80 ); // the suggested ratio 0x80 msdelay( 100 ); SPI_sendCommand( OLED_SETMULTIPLEX ); SPI_sendCommand( 0x1F ); msdelay( 100 ); SPI_sendCommand( OLED_SETDISPLAYOFFSET ); SPI_sendCommand( 0x0 ); // no offset msdelay( 100 ); SPI_sendCommand(OLED_SETSTARTLINE | 0x0); // line #0 msdelay( 100 ); SPI_sendCommand( OLED_CHARGEPUMP ); SPI_sendCommand( 0xAF ); msdelay( 100 ); SPI_sendCommand( OLED_MEMORYMODE ); SPI_sendCommand( 0x0 ); // 0x0 act like ks0108 msdelay( 100 ); // 0x0 act like ks0108 SPI_sendCommand(OLED_SEGREMAP | 0x1); SPI_sendCommand(OLED_COMSCANDEC); SPI_sendCommand(OLED_SETCOMPINS); // 0xDA SPI_sendCommand(0x02); SPI_sendCommand(OLED_SETCONTRAST); // 0x81 SPI_sendCommand(0x8F); SPI_sendCommand(OLED_SETPRECHARGE); // 0xd9 SPI_sendCommand(0xF1); SPI_sendCommand(OLED_SETVCOMDETECT); // 0xDB SPI_sendCommand(0x40); SPI_sendCommand(OLED_DISPLAYALLON_RESUME);// 0xA4 SPI_sendCommand(OLED_NORMALDISPLAY); // 0xA6 SPI_sendCommand(OLED_DISPLAYON); //--turn on oled panel } void GPIO_INITIALIZE() { EALLOW; GpioCtrlRegs.GPAPUD.bit.GPIO10 = 0; // Enable pullup on GPIO8 GpioCtrlRegs.GPAMUX1.bit.GPIO10 = 0; // GPIO8 = GPIO8 GpioCtrlRegs.GPADIR.bit.GPIO10 = 1; GpioCtrlRegs.GPAPUD.bit.GPIO11 = 0; // Enable pullup on GPIO8 GpioCtrlRegs.GPAMUX1.bit.GPIO11 = 0; // GPIO8 = GPIO8 GpioCtrlRegs.GPADIR.bit.GPIO11 = 1; GpioCtrlRegs.GPAPUD.bit.GPIO12 = 0; // Enable pullup on GPIO8 GpioCtrlRegs.GPAMUX1.bit.GPIO12 = 0; // GPIO8 = GPIO8 GpioCtrlRegs.GPADIR.bit.GPIO12 = 1; EDIS; }
Code:void putc(unsigned char aChar, Uint8 page, Uint8 startColumn) { Uint8 i; if((aChar >= 0x20) && (aChar <= 0x7E)) // normal ASCII Char { aChar -= 0x20; // subtract to match index } else if (aChar >= 0xA0) // extended UTF8 char { aChar -= 0x41; // subtract to match index } else // char not available { aChar = '?' - 0x20; // make a ? } cmd_PageStartAddress(page); cmd_ColumnStartAddress(startColumn); for(i=0;i<5;i++) { SPI_sendData(pgm_read_byte(&font[aChar][i])); } SPI_sendData(0); }
