Here is shown the router and end device of the three part system.Real quickly the radio in use will be an n24RF01 with a pro mini to control the data the battery for both are 12 volt 1800mAh. For the router I will use a PIR to sense the surrounding area, then relay if change is met. the end device is located away for the router sensor and is mobile to make it harder to locate. While being happy with the end device I have ran in to a problem with the router.
It takes a minute or so for the PIR to calm down and not sent an out signal. So I have placed a 7555 in line with the pro mini to stop the faults signal so that it has time to work properly. To use the 7555 as a switch I would like to shut off the line from the 3V line to the pro mini for one minute before turning it on for full time power.( I did note that the I had cut the mail power line to the PIR which will cause an error).
I want to use the 7555 if it is possible and I just don't know how tho make the circuit for it. Any help to this problem would be great............Pat
