I recently learned using transistors now i want to buy a kit for some common MOSFETs so that i can experiment and learn, can you please advise some N-Channel MOSFETs for switching and PWM purpose, (mostly using for turning on/off electronics modules, Relay & Motors)
100mA to 800mA 3.3v battery operated circuits SMD/DIP
1 to 3Amp 5v 12v 24v SMD/DIP (TO-92)
(I'm not looking for wide supporting range rather i would like to buy best fit, for example XYZ best fit for 700/800mA some ABC best fit for 150/100mA so that later i can use them in projects.)
I will get back to forum with some circuit setup to learn further.
Edit 1:
I have test PCBs where i can solder SMD MOSFET, breadboard compatible are also welcome but i need both as in one order i want to buy as much as i can (just to avoid shipping delays)
Edit 1:
