Adjustable frequency & amplitude function generator
shteii01
Joined Feb 19, 2010
4,644
Hello, guys...
I have achieved to get two of the waveforms(square and triangle) I need, amplitude stable over frequency. However, when I integrate the triangle to get the sine, this sine changes its amplitude as I change the frequency. How could I fix this?
I have attached the design. Hope you can help me out...
It is called Bandwidth Product. As your frequency increases, gain decreases.
Use additional op amp configured as amplifier to do just one thing, to amplify the signal.
RichardO
Joined May 4, 2013
2,270
To get a sine wave that does not change in amplitude you want to put the triangle wave through a nonlinear diode or transistor shaping circuit.
AnalogKid
Joined Aug 1, 2013
12,274
Not in this case. His amplitude is decreasing with frequency because the integrator is acting as a single pole lowpass filter. As mentioned in previous posts, he needs to use a sine-shaping circuit that is based on voltage levels rather than time constants.
ak
MrAl
Joined Jun 17, 2014
13,793
Hello, guys...
Just so you know, when you integrate a ramp you do not get a sine wave, but if you do it right you get something that looks like a sine wave but will have distortion. Also, the amplitude as a rule will in fact change with frequency, and that means you need some sort of AGC also.
The plot shows the difference between 1/4 cycles of x^2 and cosine functions. The x^2 function shown is what you get after the integration, ideally.
Just to note, the 3rd harmonic amplitude is 1/27 which is about 3.7 percent, and the 5th is 1/125 which is 0.8 percent, and the 7th is 1/343 which is about 0.3 percent, and of course they keep getting lower and lower the higher we go. So the x^2 (or rather t^2) wave isnt that bad as long as it is done right.
Computing the THD over harmonics from 3 to 1111 i get a little over 3.8 percent.
Also, to do it right you may need an auto zeroing circuit (which can come in many forms) in order to ensure that any offset does not cause the integration to ramp up or down into output saturation. If that were to happen you'd get terrible distortion.
