Hey guys,
I have been assigned a task to design an adjustable audio amplifier. the circuit should be able to tune into the edge frequencies fl and fh as well as A1, and A2 as seen in the attached file below. Furthermore, it is anticipated that I need to design various filters for different frequency bands ( eg. high pass filter for f ≥ fh). It is also required to properly filter and handle 50Hz tone that might be injected from the power supply.
Given:
A1 = 24
A2 = 1.6
fl = 3108
fh=11920
Any suggestions? I have tried looking into multi-stage amplifications but I don't know if I am on the right track
Thank you very much
Given:
A1 = 24
A2 = 1.6
fl = 3108
fh=11920
Thank you very much
