Adding alarm to Digital Clock
Q-ball
Joined Apr 16, 2019
Hi folks,
I'm new to the site as a user. I'm currently in the middle of a project for school where I'm building a 12 Hr digital alarm clock. I've got everything except the alarm figured out. This is all done using 7490 and 7492 ICs along with the 7447s and Seven Segment displays.
Where I'm hung up at is the alarm. My partner and I are trying to switch the display from showing the time to displaying the alarm time in order to set it. I was wondering if something along the lines of tri state buffers could be used for something like that. I'm not looking for the answers themselves, but maybe a direction to look in. Also looking for information on how to set an alarm. I'm guessing some sort of comparator setup? Or an IC that can do that is built for that purpose?
Any help is greatly appreciated!
djsfantasi
Joined Apr 11, 2010
9,237
So this is schoolwork! It belongs in the Homework Help forum.
I’ll give you one hint. But we’re supposed to guide you to a solution; not provide one. Investigate 2:1 demultiplexors. One select signal chooses between two sources.
How are you going to set the alarm time? And how are you going to tell when the alarm time has occurred?
AnalogKid
Joined Aug 1, 2013
12,289
Hint - this is conceptually easy, but it will take over a dozen additional chips to implement.
Also - multiplexer, not demux. Many CMOS parts are bidirectional. TTL parts are not.
ak
Q-ball
Joined Apr 16, 2019
Thanks folks! I’ll definitely check out the multiplexers. I did say I was not looking for the answers, rather the direction. Thanks again.
djsfantasi
Joined Apr 11, 2010
9,237
Oops! Mux or demux. One of those. I always get them confused. :(
