Add Physical Momentary Push Button Switches to SONOFF 4CHPRO DC Motor
jd_aus
Joined Oct 4, 2018
Hi
I have a Sonoff 4CHPRO that controls a DC Motor wired as per below. All works fine except I would like to add a physical switch to the setup.
How could I add 2 momentary push button switches (1 forward/1 reverse) to this circuit?
JD
ElectricSpidey
Joined Dec 2, 2017
3,358
Also, before designing any manual controls make sure the controller disengages both power lines to the motor when not controlling the motor.
Otherwise, you will have to take this into consideration when designing the manual controls.
jd_aus
Joined Oct 4, 2018
Thanks for the replies. Yes I have considered using DPDT toggle switch - but preference is for push buttons.
I need a bit of help with the circuit and where to wire the switches in, assume a few diodes would be required as well. Any chance someone could draft up a diagram to help me out ?
Thanks.
