AD 620 Instrumentation Amplifier simple connection diagram
Mihran
Joined Nov 3, 2017
Hello.
I am new in pcb design except of student years.
I am trying to connect AD620 Instrumentation amplifier.
Below please the circuit design, which I made in real word using breadboard, AD620, and a controller to generate analog signals.
According to AD620 datasheet, Gain = [(49.4 kOm / R(gain) ) + 1]. Thus, in case of R(gain) = 14.7 kOm, the Gain of the AD620 should be 4.36.
PARTS PROPERTIES
R1 = R2 = 21.7 kOm
R (gain) = 14.7 kOm
V1 = 5V
V2 = I change the values from controller's GUI
MEASUREMENTS RESULTS (M2 Voltmeter).
V2 = 0.2 V - - - - - M2 = -2.115V
V2 = 0.5 V - - - - - M2 = -2.115V
V2 = 0.8 V - - - - - M2 = -2.099V
V2 = 1 V - - - - - M2 = -2.012V
As you can see there are incorrect results.
Please, help me to understand what is incorrect.
Thanks.
38,952
V2 and VREF are floating.
They both has to be referenced to the virtual ground voltage (junction of R1 and R2).
Since VREF has a 10kΩ impedance it must be connected to a low impedance virtual ground, which can be made by connecting an op amp follower circuit to the junction of R1 and R2.
Easier is to use two power supplies as shown in the data sheet.
Mihran
Joined Nov 3, 2017
Thank you for answer.
The V1 and V2 are generated from the same controller(configurable from GUI) and have the same ground.
There is no circuit following to OP AMP. I just wont to see gained signal on the multimeter screen.
GopherT
Joined Nov 23, 2012
8,009
That is the point, you cannot be successful with a simple multimeter, your InAmp is amplifying the output signal, but your reference needs to be current amplified (with an opAmp) to make sure you have an accurate output. If you don't need an accurate output and can accept a 1 to 10% error (or so), then you can connect the multimeter to the ref and output pins. Before doing that, you cneed to connect V2and Vref to the center node of a voltage divider made With two 1k resistors and connecting them to 0 and Vsupply
Mihran
Joined Nov 3, 2017
Thank you for help, GopherT.
Although there was about 20 % error, IT WORKS.
So I can move forward to next steps.
