Accelerometer signal conditioning (ADC reading)
jadkh
Joined Apr 2, 2021
22
I found a 3-axial accelerometer with +/-500g that has a +/-1.25V range. The bias voltage (0g) is at half of the reference given (It does not give negative voltage).
If I'm supplying it with 3.3V, the bias voltage will be at 1.65V, so the range will be nominally 0.4V to 2.9V.
I am to read it with a 12-bit resolution ADC (ADS7038).
Can anyone help me with matching the readings of the ADC to obtain -500g at 0.4V and +500g at 2.9?
I appreciate your help
jadkh
Joined Apr 2, 2021
22
Yes, this is what I am willing to do, but I don't know how to do it.
If I use this formula, I will obtain 496 at 0.4V, and 3600 at 2.9V.
How do I obtain -500 for 0.4V and 500 for 2.9V ?
ericgibbs
Joined Jan 29, 2010
21,651
hi j,
Very basic program. the first entry in the bracket is the Value.
C-like:
float Acc1= 0;
void setup() {
  Serial.begin(9600);
void loop() {
Acc1 = map(0.4,0.4, 2.9, -500, 500);
// Serial.print("Acc1= ");
  Serial.println(Acc1);
   delay(1000);
Acc1 = map(2.9,0.4, 2.9, -500, 500);
   delay(1000);
jadkh
Joined Apr 2, 2021
22
Thankyou for your reply.
Can you please explain what did the map function did? And why is there 2 of them?
Sorry for my basic knowledge
ericgibbs
Joined Jan 29, 2010
21,651
hi j,
The MAP function will not accept decimal value, so for demonstration I have multiplied by 10
I used different values in the last Sketch to show the limits
This version increments the Value and outputs the result of the MAP operation.
The simple sketch just demonstrates the method, you will have to fine tune it.
What are the Lowest and Highest values coming from the ADC via the SPI.??
E
C-like:
float Acc1= 0;
float Val1= 0;
void setup() {
  Serial.begin(9600);
  Val1= 4; // Note Decimal Value *10 into Integer
void loop() {
Acc1 = map(Val1,4, 29, -500, 500);
  Serial.print(Val1);
  Serial.print(" ");
  Val1=Val1+1;
   delay(500);
jadkh
Joined Apr 2, 2021
22
Hello
So it is simple math, thanks for the clarification.
In fact, I did not receive the components, so I am just preparing for later. And plus, I have a report to make about the machine.
I have another question please. What about filtering my output? Does it really matter if I'm oversampling? And if it matters, do I need to build one by myself or there are pre built anti alias (low pass filter)
35,312
You can use the equation of a straight line.
y = mx + b
where
x is the independent variable, your ADC value or measured voltage
y is the dependent variable, your acceleration
m is the slope
b is the intercept on the y-axis at x = 0
You have two data points:
(x1, y1) = (0.4, -500)
(x2, y2) = (2.9, 500)
If you desire, you may replace your x values with ADC values
Calculate the slope m.
m = (y2 - y1) / (x2 - x1) = (500 - (-500)) / (2.9 - 0.4) = 1000 / 2.5 = 400
Calculate the intercept b using either of the two given data points and your calculated value of m.
b = y - mx
for example, using (x2, y2)
b = y2 - mx2 = 500 - 400*2.9 = -660
double check using (x1, y1)
b = y1 - mx1 = -500 - 400*0.4 = -660
Hence the equation is
y = 400x - 660
jadkh
Joined Apr 2, 2021
22
y = mx + b
where
m is the slope
b = y - mx
y = 400x - 660
Thank you! It's very clear now
If you decide to filter, post the signal details and I will use LTSpice to check the filter.
E
My sensor has 2-6000Hz frequency response.
In the norm (EN1177) they said we need and 12-bit ADC, sampling at over than 20KSPS, and an anti-alias filter of -30dB at the half of the sampling frequency.
Is there a problem if I sample at 1MSPS?
When building an anti-alias filter, should I consider half of the sampling frequency like stated by the norm, so at 500KSPS?
Or can I build it at 10000Hz to eliminate other frequencies.
The ADC selection is not definitive, so please consider any ADC with the sampling rate of >20000Hz.
ericgibbs
Joined Jan 29, 2010
21,651
hi j,
What is the Accelerometer attached too and how are you using the output data.?
Look at the over sampling Program options in the ADC. d/s 8.3.5
E
jadkh
Joined Apr 2, 2021
22
The accelerometer is placed in a fake head for drop tests.
The output data is going to LabVIEW using linx and we use the data to calculate the velocity and height
ericgibbs
Joined Jan 29, 2010
21,651
hi jadkh,
Thank you, the reason for asking, if you are planning for say 500KSPS, is the MCU capable of processing the data at that rate.?
So it's really for impact force and deceleration measurement of an object hitting various surfaces.?
How do you plan to store this data at this rate or will it be displayed on a screen
E
BTW: I did some quick tests for the ADC data out at those voltages 0.4v and 2.9v, assuming a max 4096 decimal value, looks OK with the MAP option.
