AC square wave from 555
38,508
A basic Schmitt trigger RC oscillator the scope shows 0.4V positive.
That circuit with a standard TTL circuit will work poorly or not at all in practice since the feedback resistor is too large to source the 1.6mA needed to pull the TTL input low.
27,523
Try a CMOS gate (CD40106, or CD4093), instead of a 74xx gate. A high value resistor between the gate input and a supply rail can be used to adjust the duty-cycle.
As I read the request the TS was asking for a way to obtain a zero-centered square wave, that is, equal positive and negative excursions. Duty cycle was not mentioned.
sparky 1
Joined Nov 3, 2018
1,218
Hi
Alec_t has a winner, an almost perfect 50% by going to the CD4093BP !!! equal it is beautiful. The resistor value had to change to 26.3K also like having the other gates available. sorry the other idea did not work. The old part was standard 7414N
Alec_t
Joined Sep 17, 2013
15,119
You have one input of the 4093 floating. That's a no-no with CMOS circuits. Connect the two inputs together. Since the 4093 is a quad gate IC, in the real world all unused inputs must be connected to something; usually ground or the +ve rail as appropriate.
27,523
This is most certainly true in the real world, but it may not matter in a simulator. That is important for folks to understand.
danadak
Joined Mar 10, 2018
4,057
A basic Schmitt trigger RC oscillator the scope shows 0.4V positive. How do I add offset control so positive and negative are equal ?
Is it better to move to an op amp circuit ?
Yes on OpAmp.
The problem with CMOS gates, even ones with Schmidt front ends, is severe
T & V dependency of thresholds, they vary all over the map. Same for many caps
generated timing.
The problem of exact 50% duty cycle easily solved (if you stay with RC gate solution) running osc at 2X and followed
by a flip flop /2.
Regards, Dana.
AnalogKid
Joined Aug 1, 2013
12,131
I thought about that. I could turn the voltage regulators to +/- 6 or 7 volts no problem.
I was just wondering about whether the 555 will also need the ground as a reference? If not, happy days!
As above, this will work if you are careful about the connections of control signals and external components. Note that the 555 decoupling cap still should go between its VCC (or Vdd) and GND pins.
The simplest solution is an output coupling capacitor. At 22 kHz and a 10 K load, a 0.1 uF coupling capacitor will create a high-pass network with a corner freq of 160 Hz. This is *way* below 22 kHz, and wont affect the squareness of the output waveform.
ak
Audioguru again
Joined Oct 21, 2019
6,826
I would make the Schmitt Trigger Nand gate an inverter by connecting the unused input to the positive supply, then the slightly different threshold voltages of both inputs won't fight over which one triggers first.
sparky 1
Joined Nov 3, 2018
1,218
Thanks, outstanding specific information. I will leave a jumper and a blank op amp section with room for adjust.
The old 4069 hex inverter circuit is in a shoe box that my wife wanted to throw away. The circuit after that was a 7490 decade counter.
sparky 1
Joined Nov 3, 2018
1,218
Thank you audio guru and others, that is so true. The projects from the 60's early 70's will stay in the shoe box. The Alec t cd4093 are on order. As mentioned the simulator and the real circuit could still have issues but I have a good feeling that the 4093 will work with the output of Arduino Uno. How exactly I am not sure? I ordered 6N137 opto coupler. The output of the 4093 is for audio range. The concern about symmetry to help check before and after inserting this output stage. The opto isolation is an attempt to improve the purity of the square wave at least attempting to get the best signal from the Arduino. I believe that a low pass filter will remove noise. Not sure but I think that if clean edges are transmitted by the 6N137 the 4093 might give a clean square wave.
