Function Generator for Square wave ---> Triangular wave---> Sine wave
Mike2526
Joined Nov 10, 2020
110
Hello everyone, Hope you are doing great. I have designed a function generator for sine wave (V=5Vpp) by using LM324 OP-Amp. I am interested to design this generator for the frequency of 95.5Hz. I found this circuit online, after designing this circuit, i found there is no signal at any stage. I am afraid why is it? I designed this circuit in LTspice simulation tool. I need expert's help in this regard. The JPEG and .asc is attached for your review, please. I shall be grateful to you in this act of kindness.
schmitt trigger
Joined Jul 12, 2010
2,260
After you get the circuit running correctly, replace the last stage with a 2nd or 3rd order LP filter, to significantly reduce the distortion.
That is, If you do require lower distortion.
Mike2526
Joined Nov 10, 2020
110
hi Mike,
This is what I see, required the LTS timings adjust to run.
E
Thank you so much for your kind reply. But i have another question that the output (sine wave) frequency is about 27Hz, but I want to enhance about 95.5Hz and output voltage's amplitude must be required about 5V (10Vpp). what values I need to choose for resistors and capacitors? I shall be grateful to you for this kindness, if you will suggest me appropriate values.
