AC Mains to 24Vdc/9A Power Supply Advice
EDANN
Joined Oct 24, 2016
25
Hello
I am having trouble finding a reasonable power supply (AC to DC), specifically of 24 VDC and a current range of 9 ADC. Every power supply i find has a weird plug, like a R7B, that i cannot find an adapter easily. How do you fellas find a power supply, not an adjustable one, that you can connect to your projects. Any ideas or advice, thanks!
EDANN
Joined Oct 24, 2016
25
I am in North America.
Hey Ramussons, i would need to wire an electrical plug for the AC (3 wires), and then wire my DC (2 wires) to my circuit, am i correct?
I was wondering if there was something like an already of the shelf product, this link here is what i would want, it looks nice, and is light, but i just can't find a connector for the DC side! Any ideas, maybe what i am looking for just doesn't exist!
http://www.jameco.com/z/GS220A24-R7...Top-Power-Supply-24-Volt-9-2-Amp_2099286.html
EDANN
Joined Oct 24, 2016
25
Perhaps if i could connect it to some kind of terminal block, or it would have an adapter that would do it? I like the look of electrical quick connectors and banana connectors, but i just don't see how i could connect this to a power supply. I am new to the electrical stuff so i am quite unaware of connectors and such. I have a motor with two leads, and i want a power adapter to connect it, and does not looked jimy-rigged. Any possible connections options, maybe i am over thinking this.
Kermit2
Joined Feb 5, 2010
4,159
There are so many connection options because there are so many devices and ways to wire them that the rich selection of accessories is a good thing.
First you need to know exactly what you have in the way of items to interconnect. I do mean exactly.
The options thin out based on what items you are connecting and your specs., such as, outdoor, indoor, high temp, and so on.
Get us a pic of the items and your specs (needs) of operation and we will help you make a professional choice for connecting them.
Edit: the more details you give the better the answers become.
EDANN
Joined Oct 24, 2016
25
Hey sorry for the few details, i really am just unsure where to start. The DC voltage i want is 24 V, and have a maximum predicted current of 10 A.
Nonetheless, here are a few parts i think would work
http://www.tme.eu/en/details/pc-mdj-402-4p/dc-power-connectors/ninigi/
https://www.alibaba.com/product-detail/Japanese-Standard-3-Pins-power-cord_1959233910.html?s=p
These would connect together i think?
Or would it be easier to find and use a barrel connector like this?
http://www.ebay.com/itm/24-VDC-5A-S...8771b63&pid=100005&rk=4&rkt=5&sd=282182542133
http://www.digikey.ca/product-detail/en/cui-inc/PJ-082BH/CP-082BHTR-ND/3477156
And what is the name of a breadboard that can deal with the current and voltages i plan to use?
I hope this helps out, thanks for your help!
Alec_t
Joined Sep 17, 2013
15,167
You would be pushing those connectors to their limit at 9A or more. Not good practice.
All breadboards should be able to cope with 24V, but they are mostly (all?) designed for low currents (mA) ..... not 9A.
