You can see the gray stripe of the top of the capacitor in the photo. The diode was connected to the positive side of the capacitor, since obviously we're sending positive voltage across the diode.Where was the -ve end of the capacitor connected? What is the PSU output voltage in that situation?
The output voltage of the PSU is 29.7VDC or so even in green mode at 4.7kHz. The output spec for the device is to be at 30VDC at all times, up to 500mA.
I can do that tonight if you want to see it.You could also try with the diode connected direct to pin 5 of the transformer/R7 and the -ve of the capacitor/load resistor to J2 or the heatsink, in case Q2 is actually faulty.
The frequency change across the transformer at Pin 8 is odd to me as well. It's more than double the frequency at the primary! Unless I should be using Pin 6/7 as the other pole rather than the heatsink for the frequency measurement?I would expect it to be same frequency as on Q2...
It just isn't ramping up when on-load. But why?
I wouldn't say that this device isn't ramping up when a load is applied. I have no measurements currently of exactly what happens at that moment when the load is applied and the frequency increases. The printer does actually come on, which means it is drawing at least 200mA. It's just when the print head starts to move, causing a surge to 500mA or greater, the overcurrent protection mechanism kicks in and shuts everything down, I guess by simply stopping the switching and leaving the MOSFET in 'off' position.
Would it help if I can find a more stable load and figure out at exactly what resistance the IC switches out of green mode, and if it can even run in regular mode (full frequency) up to a certain amperage?
I still believe that the SENSE circuit is responsible for the shut down, and I'll remind you that I found yesterday that the R19 in that circuit appears to be bad and reading too low in ohms.
