I think that's working OK. Your meter seems to deliver a constant 1mA on the ohms range, so you get a very on/off experience rather than the gradual change I'd hoped to see.Not seeing quite this. With the 9V battery disconnected, Drain-to-ground resistance reads Overload (OL) at all times as I turn the potentiometer and 0V across the 1 ohm resistor. Upon connecting the 9V battery, I get overload initially, but upon a slight turn of potentiometer drops to 2 ohms at all times as I turn the potentiometer the rest of the way up. On the second meter, getting 1mV across the 1 ohm resistor at all times as I turn the potentiometer with the 9V battery connected.
I think it's safe to try the USB supply.
