AC-DC converter- On Board charger
rreddy426
Joined Jan 24, 2019
19
I am working on designing on board charger. For this first stage convert AC power to DC power. For this I took, totem pole configuration as example.Here RL is connected as a load resistance. In this configuration, capacitor charges and discharges through RL. When RL is removed, I see capacitor charges to higher extent and goes beyond limit. What should be done to limit the capacitor storage when RL is removed.
Thanks,
Sam
wayneh
Joined Sep 9, 2010
18,104
Two obvious kludges are to: 1) Use a cap with a higher rating, or 2) Add enough resistance in parallel to the load to prevent the spike. It's possible that a high resistance, a trivial load, might be enough. If you need anything more elegant than that, I'm out.
