Ac Communication
Status
Not open for further replies.
saleemsm
Joined May 15, 2006
36
Greeting hgmjr!
But i already know the information that is there... it is not enough... i need more inside stuff on steganography... i know what is crogenics but need links that tell the latest advancement in the same... thx for you support...
take care
hgmjr
Joined Jan 28, 2005
9,027
saleemsm said:
Greeting hgmjr!
take care
Sounds like you are in the advanced stages of learning steganography. As for Me, I'm on the outside looking in. Seems like I recall that it has something to do with hiding information in the form of text in the pixels in a digital picture or some such magic.
Take a look at amazon.com and see it they have a book that suits your advanced level. You should be able to peek inside one of their books to see if it has the kind of info you are looking for.
You may want to seek out a forum that deals primarily with the subject of encryption. Surely there is one out there that caters to encryption buffs.
hgmjr
saleemsm
Joined May 15, 2006
36
Thanks hgmjr
there is one important help that i need.
that is the circuits and codes for the keyboard and display interface of 89c51.
will look into the book you said and will let you know... but just in case can you tip me the link to such a forum for encryption?
saleemsm
Joined May 15, 2006
36
the site is good for steganography have still to look into it deeply; and i haven't seen the book on cryogenics yet.
but what about the Keyboard and display interface hgmjr?
saleemsm
Joined May 15, 2006
36
Thanks hgmjr
it was helpful!
working on my project now... will start atleast with simulation... any suggestions on how to proceed with the project? shall i start with simulation or prototype?
hgmjr
Joined Jan 28, 2005
9,027
If there is any sub-section of your circuit whose behaviour you are not certain, then you can simulate it just to convince yourself that it will perform as you expect.
Otherwise, I would just go ahead and prototype the design you have in mind.
hgmjr
saleemsm
Joined May 15, 2006
36
thks hgmjr
sry that i couldn't repond any sooner. i had a chance to present a paper on my project and it bloopered... i did well i don't know why i was not awarded a prize... it had set me back by a day... will work on my project just now... i have a circuit for keyboard interface but i doubt its working... can you explain?
saleemsm
Joined May 15, 2006
36
please let me know about the circuit i want to know its working clearly i am not sure about the schmitt trigger's working here
hgmjr
Joined Jan 28, 2005
9,027
The circuit appears to be set up to filter the output of the switch prior to the schmitt logic gate. It looks like a crude switch debouncer circuit.
What are you trying to accomplish with the circuit?
hgmjr
saleemsm
Joined May 15, 2006
36
key board debounce...
understood the working now but the problem is why schmitt trigger? why not FET? and i think schmitt trigger has two inputs one reference and the other being the input which one of the two in input?
have a nice day
hgmjr
Joined Jan 28, 2005
9,027
have a nice day
Actually what appears in your attachment is a 2-input schmitt trigger NAND logic gate. A schmitt trigger logic device is often used when the input signal is both a bit noisy and likely to have a slow rise-time and/or fall-time. The rise and fall time of the input to the schmitt trigger of your circuit may be fairly slow since the resistors and capacitor in your circuit form a low pass filter. Both inputs to the gate are identical and can be used interchangeably. The input hysteresis levels are fixed by the internal devices design.
A schmitt trigger input possesses what is referred to as "hysteresis".
Rather than try to explain hysteresis to you, I have provided a link to the AAC Forum Tutorials section that explains the topic.
http://www.allaboutcircuits.com/vol_4/chpt_3/11.html/schmitt
I suggest you review the material and then if you have any questions you can come back to this thread and post them.
A discrete FET could be used but it would entail a bit more design effort to get the input bias circuitry set just so and the output load circuitry set up. The use of a logic gate is preferable because it is available at a reasonable price and logic gates are easy to come by since they are made to an industry standard specification by many different semiconductor manufacturers.
hgmjr
saleemsm
Joined May 15, 2006
36
I am sorry to deviate from the topic.
Thanks for the info hgmjr will look into it... but i have a good news to all of you...
I GOT PLACED IN US TECHNOLOGIES.
i would like to know more about the company so if you guys could lend me the info.
hgmjr
Joined Jan 28, 2005
9,027
Is this the company you are referring to?
http://www.ustechnologies.com/index.cfm
If so, you should be able to find some good information on their corporate website.
hgmjr
Status
