About the arrganment source ???
Long292
Joined Nov 18, 2018
16
I'm having a 48V and 12,5 A source how can I use it for a connection includes three peltiers 12V 10A and a temperature sensor 12V 10A and all connections are serious and I want all of this will work max power so how can I use the source for this situation?
34,777
Connect four 12V TEC in series to a 48V source.
The TECs might not be balanced hence the power consumed by each might not be the same.
danadak
Joined Mar 10, 2018
4,057
If you only want to connect 3 then use a power R to drop V, very inefficient,
or a switch mode converter to translate the 48 V to 36V. Some 48V supplies
have trims to change their output V, but a 25% trim range is not "normally"
found in 48 V supplies.
Or use 4 peltiers (as previously (recommended) at lower current to get same heat
transfer results.
Or build a constant current source, but if done linear very inefficient.
Regards, Dana
