I thought I did that... did you see the zip file containing the pictures? They're as close up as my camera can get. If you need closer... then I can do that after Christmas when my wife opens her gift
Ehentha !!
What is Divehi?it means " Really " in Divehi.
A language. And apparently someone here speaks it.What is Divehi?
Most likely the latter. The ports are supposed to be current limiting but they usually use a fuse instead. If it still works and there is still voltage there, you shouldn't of hurt anything if it was ground you hit (and not the audio/video pin).Note that I accidentally briefly shorted the 3.3v and ground while the unit was powered. The screen briefly turned off and the audio went dead - it came on momentarily after I corrected the short. Is that evidence of what I proposed in the previous paragraph? Or is that simply that I nearly ****ed up my unit and caused it to "reboot"?
- Steven
Pin 2, which is the one connected to 3.3 V, is actually a digital input which turns off the screen and the speaker when pulled to ground. The 3.3 V are maintained when unconnected by a pull-up resistor of roughly 20 kΩ so that the gate voltage is not floating freely, by the way; we put a 18 kΩ resistor between pin 2 and pin 1 and the voltage on pin 2 fell to about 1.5 V and we also measured the current between pin 1 and pin 2 when shorted and it was of something between 0.1 mA and 0.2 mA. When you shorted this pin to ground, you disconnected the screen and the speaker, but that's the expected behaviour. Note that we got audio output through pin 4 both with pin 2 connected to ground and disconnected (in which case we got audio both on TV and on the monitor device).[...]Of the 5 pins, 1 does nothing [...], 1 is 3.3v power and 1 is ground. [...] Note that I accidentally briefly shorted the 3.3v and ground while the unit was powered. The screen briefly turned off and the audio went dead - it came on momentarily after I corrected the short. Is that evidence of what I proposed in the previous paragraph? Or is that simply that I nearly ****ed up my unit and caused it to "reboot"?
- Steven
by Aaron Carman
by Aaron Carman
by Jake Hertz
