a timer that goes logic high or low every 15mins ( using tiny85 chip)
be80be
Joined Jul 5, 2008
2,395
This what you you used
avrisp.name=AVR ISP
avrisp.communication=serial
avrisp.protocol=stk500v1
avrisp.program.tool=avrdude
avrisp.program.protocol=stk500v1
avrisp.program.extra_params=-P{serial.port}
be80be
Joined Jul 5, 2008
2,395
# STK500 firmware version v1 and v2 use different serial protocols.
# Using the 'stk500' protocol tells avrdude to try and autodetect the
# firmware version. If this leads to problems, we might need to add
# stk500v1 and stk500v2 entries to allow explicitly selecting the
# firmware version.
be80be
Joined Jul 5, 2008
2,395
You on two roads here one is loading the code to turn your arduino into a programmer
Thats this one
And one that burns the bootloader thats after you load the
ArduinoISP code I posted
timtim1234
Joined Nov 30, 2023
246
In case you are wondering, this is why people told you to use an Arduino board instead of a raw AVR chip.
yes but it looks like 1,000's of people have programmed the raw chip without problems and there is nothing i can find on the web about this problem which is weird. It just don't make sense, I am not sure what to think.
BobTPH
Joined Jun 5, 2013
11,662
Thousands of people ski down expert slopes too, but not on their first day of skiing.
timtim1234
Joined Nov 30, 2023
246
true but you have to start some where :) also many youtube videos showing people doing the same thing And steps iam doing so i don't know what is going on. so i don't think its was asking to much its not like its "expert" setup/circuirt here. again no where online talks about this problem so must not be a common problem.
djsfantasi
Joined Apr 11, 2010
9,237
Many people don’t goto their tennis instructor to learn how to ski. Might work for the bunny hill but not black diamond slopes.
35,242
Welcome to the world of electronics hardware and software, computers, programming, and debugging.
Your situation is not unique. Many times one is faced with multiple problems. For example, let us say that there are three problems happening at the same time. You cannot succeed if only one problem is resolved. Oftentimes, one of the problem is misinformation or a situation that is out of date.
When you finally have all the problems resolved and your system is up and running, you look back and think how "silly" was each problem.
timtim1234
Joined Nov 30, 2023
246
I don't think me programming a tiny85 would be an "expert" thing to do, it looks straight forward thing to do with all the info that was out there. That's like saying don't walk, you might fall!
